Re: Re: Re: Second Tractor Needed
Posted by Hugh MacKay on July 14, 2004 at 03:01:18 from (216.208.58.164):
In Reply to: Re: Re: Second Tractor Needed posted by Dick Davis on July 13, 2004 at 05:32:53:
Dick: You nailed that,no point in leaving those leaves in the field. Alfalfa probably the most sensitive but all hay crops will do it.
That is the reason I always liked the SA and 130, on 60" wheel tread they have a lot more center clearence than the larger tractors, great for big volume windrows. and it is much easier to keep wheels off the hay. I always went to direct windrow with 9 foot haybine. On heavy alfalfa it was one turn with rake and then baler. Weather cooperating of course. Only one way to have 20% protein alfalfa hay, and that is have all the leaves.
Post a Followup
: Re: Re: Re: Re: Second Tractor Needed
