Re: Re: Re: Re: Re: Carb setup
Posted by gene on July 15, 2004 at 11:54:06 from (208.144.172.158):
In Reply to: Re: Re: Re: Re: Carb setup posted by Matt on July 15, 2004 at 11:35:51:
Try the fuel system cleaner from the auto parts store. $2 - $3. You don't need to remove the carburator from the engine. The cleaner will usually do a good job. You just pour the cleaner in the fuel tank. Run the engine if you can, you should see results in minutes. If motor won't start, open the drain (pipe plug) on the bottom of the carburator and drain out a pint or two of fuel. Replace the drain plug, wait several hours then drain off another pint of two of fuel. It's worth a shot
If the tractor has been sitting for a while drain off (into a container) the old fuel and put in fresh with the fuel system cleaner.
Post a Followup
: Re: Re: Re: Re: Re: Re: Carb setup
