Re: Well I thought I got it fixed
Posted by M Miller on April 02, 2009 at 13:49:00 from (99.128.116.196):
In Reply to: Well I thought I got it fixed posted by old on April 02, 2009 at 08:25:48:
If you have a small propane torch you can fix it yourself, oxy acetylene work also but you have to have a light touch. You will need to get some 50/50 flux core solder & pick up some Laco Flux, this stuff works the best. Take an ice pick and clear, push easy, the cooling fins down to the leaking tube. If its a crack clear fins 1/2" past on both ends. Warm tube with torch & rub flux on. If you can get a small, fine wire brush on the tube that works the best but if not just keep heating & rubing with the flux until clean. Then hold your solder on the tube & heat with torch until solder flows & keep going until you have all of the leaks fixed. If the tubes are too bad come about 1 1/2" down from top tank & up from bottom tank. Clear the cooling fins away punch a hole in the tube with the pick heat with & clean with flux & solder shut. On some old & damaged radiators I have plugged as much a 15% of the tubes with out any problem. This is on Agg & Industrial equipment not Autos.Good Luck
