Re: Farmall H presure plate question
Posted by lee on July 16, 2004 at 13:43:59 from (24.24.95.246):
In Reply to: Farmall H presure plate question posted by SCOTT IN MO on July 16, 2004 at 10:18:32:
If you've got the cash and you don't want to fool with the old one, replace it with a new one. Myself, I would just replace what's needed. The pressure plate assembly comes apart so all the individual parts can be checked and replaced as needed. Release fingers wear, pins wear, springs may get soft or break. The plate itself must be flat with no cracks or serious heat checks or grooves, same for flywheel. Flatness can be checked with a good straight edge. If you are not comfortable making the necessary decisions buy a new assembly. Last one I did I put new springs, release fingers and pins on the old press plate which checked out good. I checked flywheel for flat, no serious grooves. Did not grind flywheel. Replaced clutch disk and pilot and throw-out bearings with new parts.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
