Re: Re: Re: Deer Monseiuer...IHC Corn Planter?????
Posted by J. Schwiebert on July 16, 2004 at 16:31:02 from (216.201.29.96):
In Reply to: Re: Re: Deer Monseiuer...IHC Corn Planter????? posted by Farmalldan on July 16, 2004 at 10:03:44:
The first thing I remember doing is set the stake and then driving to the other end letting the wire unroll as you drive. Then you set the other stake, turned the planter around and then you lined up the planter attached the wire in the trip arm and planted to the other end. Then you unhooked the wire from the planter, moved the wire over, insert the wire in the other trip arm and planted back. It only takes one guy but if you plant with horses or even if you plant with the tractor you get off the tractor you get off and on a lot. 2-4D I think was the key item that ended check row corn. What my friend and I do not remember is how you rolled the wire back up. Although this Deere & Mansuer my friend has is equipped with a sprocket that would power the drum the check wire goes on. We had a 13 acre field and it took the better part of the day to plant that. Since we are on this topic, When were fertilizer attachments introduced. My dad said the first planter he had was the second planter in the township with a fertilizer attachment, so about when did they become available?
Post a Followup
: Re: Re: Re: Re: Deer Monseiuer...IHC Corn Planter?????
