Re: Toasted ring gear?
Posted by David in UT (follow up) on July 16, 2004 at 22:09:33 from (66.166.251.67):
In Reply to: Toasted ring gear? posted by David in UT on July 07, 2004 at 20:35:16:
Quick update:
The 400D is back in working order! I took a file to some of the ring gear teeth to smooth out any ragged edges, then I put back in the rebuilt starter. It turned over just fine, and ran just great. 20 minutes later we used the tractor to haul an old dead tree out of a ditch. Good to go, and I didn't need to split it!
Thanks to everyone for their advice.
- David
Post a Followup
: Re: Re: Toasted ring gear?
