Farmall Tractors Discussion Board
Re: Farmall C steering
Posted by Milan on November 02, 1999 at 16:15:16 from (209.69.206.172):
In Reply to: Farmall C steering posted by Shank on November 02, 1999 at 15:13:52:
Pull the filler plug out and take a look inside. My gear box was caked with mud and no gear lube when I first brought it home. You'll need to remove the grille to get at it.
Inside is a gear and worm shaft.
third party image
Post a Followup
: Re: Re: Farmall C steering
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
