Farmall A problems (novice)
Posted by Andrew on July 18, 2004 at 19:33:58 from (204.60.241.233):
I just got a 1945 Farmall A, the tractor had not been really worked in over 5 years. The two problems that I have is the lights were working fine then all of a sunden the lights "all of them" went out (is there a fuse some where cant seem to find one) The other problem seem I seem to notice that there is a leak around the 1st cylinder there is a little bit of oil or coolint leaking out just in that area no where else, is this all right or do I need to replace the head gasket? Sorry this is going so long but I have one last question what should the normal oil pressure should be. At first the pressure is high then after it backs off on the pressure is this normal operation?
Thanks for the help!!
Andrew
Post a Followup
: Re: Farmall A problems (novice)
