Re: 450 - Bleeding Hydraulic Pump and Lines
Posted by Aces on July 19, 2004 at 08:11:36 from (67.0.38.13):
In Reply to: 450 - Bleeding Hydraulic Pump and Lines posted by Red Raider on July 19, 2004 at 06:35:36:
The 300 350 400 450 Farmall's had a breather out the top of the reservor under the hoods make sure it is clean so the hydraulics can get air if you use one way cylinder then you can put some air pressure in where the breather is. I found if a pump has some oil in it and it is a good pump it will prime it's self.
Post a Followup
: Re: Re: 450 - Bleeding Hydraulic Pump and Lines
