Re: Alternators other then Delco for M conversion
Posted by Doug in OR on July 19, 2004 at 13:36:57 from (67.166.95.121):
In Reply to: Alternators other then Delco for M conversion posted by jonesy on July 18, 2004 at 16:01:14:
The common internally regulated alternators will have these connections in common: 1. A large BAT stud - where you connect the wire coming from your ammeter/voltmeter/battery. 2. An exciter wire connection. Sometimes called "I" (ignition). This is the same as the "terminal 2" connection on the Delso 10SI. One-wire alternators do not have this - but those are a specialty breed. 3. Some alternators will have a "S" (sense) terminal. The Delco CS121/130 alternators will have this, but it may be hidden under the connector boot. It is already connected internally, so you do not need to connect it. You can connect it if you wish to take your reference reading right from the battery, but this is not necessary. Most Nippondenso and Hitachi alternators will have this connection and it must be used. Treat it as you would if it were pin 1 on the Delco 10SI. Good luck with this - you'll find that you can use almost any internally regulated alternator. You don't need to find one with a large output. Tractors just do not need the extra size.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
