Re: Farmall H dead in water
Posted by Roger WI on July 19, 2004 at 17:16:33 from (69.58.151.206):
In Reply to: Farmall H dead in water posted by KCFarmall on July 19, 2004 at 06:30:19:
As others said, probably need to check the timing. But if it slipped out of time, you probably have some problem in the distributer as Farmall H's don't have timing chains. They are gear driven from the crankshaft to idler to camshaft to distributor. I have seen problems with the small drive gear in the distributor if it hasn't been lubricated. May check for cracked distributor cap also. Roger
Post a Followup
: Re: Re: Farmall H dead in water
