Farmall A implements
Posted by Jim on July 19, 2004 at 22:45:23 from (64.40.54.63):
I was looking for a late model Ford 8N when I found this neat little Farmall A. Since the A has no hydralics and no 3 point hitch what can I do to use 3 point implements? She's a neat little rig so I'd hate to part with her. The A has the housing for a two PTO system but has no shaft for the pulley. It 's capped off. Can you attach a pump to the second PTO shaft to run hydralics? Also one rear rim has been welded where it bolts to the hub numerous times. Where can I pick up a good hub?
Post a Followup
: Re: Farmall A implements
