Re: Farmall C clutch adjustment
Posted by K-Mo on July 20, 2004 at 14:31:28 from (65.169.189.2):
In Reply to: Farmall C clutch adjustment posted by Lance on July 20, 2004 at 11:35:32:
Lance,
If it can't be adjusted then you probably won't like the answer to the problem.
1. Did the tractor sections assembly easily or were they pulled together with the bolts? They should easily slide together if not things aren't right.
2. I don't know if it is possible on the Farmmal C but could the clutch plate be installed backwards.
Either way if it can't be adjusted most likely you will have to split the tractor again.
I have a Case 580CK Backhoe Tractor I put a clutch in. When I had it all together and tried to move it the clutch wouldn't release. The rebuilder had installed the springs incorrectly. I wasn't happy about splitting it again for someone elses screw up.
Good Luck,
K-Mo
Post a Followup
: Re: Re: Farmall C clutch adjustment
