Re: M --alternator-- rpm
Posted by Bob on July 20, 2004 at 16:05:17 from (66.163.134.177):
In Reply to: M --alternator-- rpm posted by Eric on July 20, 2004 at 15:58:50:
If it is a "one wire alternator", often the engine will need to be revved up quite a bit to get it to first charge, but once it is charging, it should charge almost to slow idle.
If it is a standard Delco alternator, as is used in many conversions, it should charge right away, at anything above a slow idle.
If it is a 12 Volt alternator conversion, the voltage at the battery should measure at mimimum, 13.5 volts, and all the way up to 14.75 volts is normal. Below the low end of that range, you have alternator problems.
Post a Followup
: Re: Re: M --alternator-- rpm
