Re: McCormick Deering 1020 rubber wheels
Posted by Mike Androvich on July 20, 2004 at 19:55:09 from (24.50.141.152):
In Reply to: McCormick Deering 1020 rubber wheels posted by Greg on July 20, 2004 at 14:45:00:
1926 10-20s did not come out on factory pnuematic tires. Industrials were available on hard rubber, but I am assuming yours is the farm version. Countless tractors were converted from steel to rubber at the local dealership or blacksmith shop. Your rear axles are more than likely the keyed type (as opposed to the splined type) so factory rubber wheels are not available. You can easily find a set of rear cutoffs if you really want them. I have several sets right now. Gladly trade them for steel!
Post a Followup
: Re: Re: McCormick Deering 1020 rubber wheels
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
