Re: Crappy running 460 update.
Posted by ChadS on July 22, 2004 at 06:40:02 from (66.228.96.172):
In Reply to: Crappy running 460 update. posted by Kelly C on July 21, 2004 at 20:33:20:
Kelly do you have a dyno? if not there is another way to check out, and find problems in carbs and igntion,, You can advance the timing,, to where the rpms drop, or sounds like it is under a load, it acts like a dyno, and if there is a misfire, in the igntion,,you should be able to find it. Look at the plugs,, are they black, brown, or white? after you run it for a while,,,, or work the engine. Like I said, the venturi may be the cause,, these engines,, have a huge intake, and intake runners, so you have lots of flow,, the problem,, is that the carb is not pulling the correct amount of vacuum through the carb when it accelerates, sure,, you may be able to make it run rich wit the load adjustment, it is the sudden drop in vacuum in the manifold when the carb opens up to WOT. I used a venturi out of an M, a lot smaller than the 460-560, well any IH 6 cyl carb, if that dont work,, VALVES. Chad
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
