Farmall Tractors Discussion Board
Re: Farmall C steering
Posted by Phil Auten on November 03, 1999 at 05:41:13 from (206.175.72.226):
In Reply to: Farmall C steering posted by Shank on November 02, 1999 at 15:13:52:
Shank,
First thing I would look at is tire pressure. Make sure both tires are up to at least 25 PSI. 30 PSI would be better. Then I would check what Milan suggested. Also check to make sure there's nothing wrong anywhere between the steering wheel and the gear case. Something rubbing or a bad u-joint, etc. If it's a wide front, check the kingpins and tie rods, if a narrow front, possibly the bearings in the gearcase are bad. My instructor in tech school always said "when troubleshooting, start at the output and work back". That's helped me solve some pretty puzzling problems over the years.
Phil
Phil
Post a Followup
: Re: Re: Farmall C steering
