Re: calcium cloride mix
Posted by Hugh MacKay on July 23, 2004 at 20:26:28 from (209.226.247.38):
In Reply to: calcium cloride mix posted by tractor dan on July 23, 2004 at 18:24:21:
Dan: It's been a long time, but I can remember using the whole bag for a 13.6x38. I think calcium chloride was close to 100 lbs per bag back then.
Anti-freeze could be a good solution in the right area. It would get quite expensive here or at your place in VT. I realize you wouldn't need it quite as strong as for a cooling system, but I think you would have to go at least 35% anti-freeze.
Post a Followup
: Re: Re: calcium cloride mix
