Re: calcium cloride mix
Posted by Farmer Bob on July 23, 2004 at 22:10:09 from (64.113.0.116):
In Reply to: calcium cloride mix posted by tractor dan on July 23, 2004 at 18:24:21:
Here's come tech info on hydroinflation:
GENERAL FARM TIRE INFORMATION
V. HYDROINFLATION
When removing fluid from tubeless tires, be careful not to unseat beads until most of fluid has been pumped from the tire. Consult your tire supplier for information on hydro-inflation equipment such as pumps, compressors, air-water conversion hardware parts, etc. Tire rotated so valve is at bottom with hydro-inflation fluid being removed.
NOTES:
Tables are based on using type 1 calcium chloride (77% CaCl2). If type 2 concentrated calcium chloride (94% CaCl2) is used, reduce specified “Lbs. CaCl2” in tables by 25%.
Values shown in tables are approximate and represent 75% fill or “valve level” fill (with valve at top of tire) which is recommended practice.
Antifreeze protection levels are shown at top of each table for different solutions.
For rear tires mounted on narrower rims, decrease quantities at the rate of 4% for each 1-inch reduction in rim width. For wider rims, increase quantities by 4% for each 1-inch increase in rim width.
Tire Size Rim Width WATER 31/2 LB. SOLUTION 5 LB. SOLUTION
Solid at +32°F. Slush-free to -12°F. Solid at -52°F. Slush-free to -53°F. Solid at -62°F.
Water Gal. Weight Lbs. Water Gal. CaCI2 Lbs. Total Wt. Water Gal. CaCI2 Lbs. Total Wt.
DRIVE WHEEL TIRES
8.3-24 7.00 13 108 11 39 131 10 50 133
9.5-16 8.00 12 100 10 35 118 10 50 133
9.5-24 8.00 17 142 15 53 178 14 70 187
9.5-32 8.00 22 183 19 67 225 18 90 240
9.5-36 8.00 25 208 22 77 260 20 100 267
9.5-42 8.00 29 242 25 88 296 23 115 307
11.2-24 10.00 24 200 20 70 237 19 95 253
11.2-28 10.00 27 225 24 84 284 22 110 293
11.2-36 10.00 35 292 30 105 355 28 140 374
11.2-38 10.00 36 300 31 109 368 29 145 387
12.4-24 11.00 30 250 26 91 308 25 125 333
12.4-28 11.00 35 292 30 105 355 28 140 374
12.4-36 11.00 44 367 38 133 450 36 180 480
12.4-38 11.00 46 384 40 140 474 37 185 494
12.4-42 11.00 51 425 44 154 521 41 205 547
12.4-46 12.00 53 442 45 158 533 43 215 573
12.4-54 10.00 58 484 49 172 581 47 235 627
13.6-24 12.00 38 317 32 112 379 30 150 400
13.6-26 12.00 40 334 35 123 415 33 165 440
13.6-28 12.00 43 359 37 130 439 35 175 467
13.6-38 12.00 57 475 49 172 581 46 230 614
13.6-46 12.00 65 542 55 193 651 52 260 694
13.9-36 12.00 51 425 44 154 521 42 210 560
14.9-24 13.00 47 392 40 140 474 38 190 507
14.9-26 12.00 48 400 41 144 486 39 195 520
14.9-28 13.00 53 442 46 161 545 43 215 574
14.9-30 13.00 57 475 48 168 568 46 230 614
14.9-34 13.00 63 525 54 189 639 51 255 680
14.9-38 12.00 67 559 58 203 687 55 275 734
14.9-46 12.00 80 667 68 238 805 65 325 867
15.5-38 14.00 66 550 56 196 663 53 265 707
16.9-24 15.00 61 509 52 182 616 49 245 654
16.9-26 15.00 65 542 56 196 663 52 260 694
16.9-28 15.00 69 575 59 207 699 56 280 747
16.9-30 15.00 73 609 63 221 746 59 295 787
16.9-34 15.00 82 684 70 245 829 66 330 880
16.9-38 15.00 90 751 77 270 912 73 365 974
17.5L-24 15.00 55 459 47 165 557 45 225 600
18.4-16.1 16.00 49 409 42 147 497 39 195 520
Post a Followup
: Re: Re: calcium cloride mix
