Re: Engine Overall in a 51 Farmall H
Posted by El Toro on July 24, 2004 at 10:17:36 from (205.188.117.22):
In Reply to: Engine Overall in a 51 Farmall H posted by OldeSarge on July 13, 2004 at 15:25:19:
Hi Sarge, You will like that old tractor even more by redoing the engine yourself. Take pictures of the engine before and as you disassemble the engine. They may come in handy when you're doing the assembly. Take some notes too. Make a note as you remove the main bearing caps so they can be reinstalled correctly. This also applies to the connecting rod caps. The numbers on the caps and rods usally face the camshaft side of the engine. Do not just throw nuts and bolts into a box as you do the teardown. Put all nuts and bolts from one section of the engine into a box and mark the box as to where they were removed. An example would be the head bolts, then the rocker arms and bolts. Pan bolts in another box. This saves time during assembly so you do not need to hunt for the correct bolts or nuts. I would get the engine degreased "cooked" once you have it stripped. Have the machine shop to check the crankshaft and install new cam bearings. They may recommend using a new cam shaft. Redo the cylinder head too. Find a good machine shop in your area. Good Luck, Hal Post it here when you have finished and have it running.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
