Re: calcium cloride mix
Posted by Alvin NE WI on July 24, 2004 at 18:07:09 from (67.50.25.41):
In Reply to: calcium cloride mix posted by tractor dan on July 23, 2004 at 18:24:21:
for 50 gallons of water use about 200 lbs. of calcium cloride which will be good for a -35 degree day. That is what my book shows.Don't worry about bad things from it IF you have a leak in a tire and repair itsoon, which are good farming practice. If you want to negleck it than pay the piper. I just took my '38 tractor apart with the calcium in it for at least 50 years, yet the rims are good.
Post a Followup
: Re: Re: calcium cloride mix
