Re: 560 hyd pump swap
Posted by Aces on July 25, 2004 at 15:37:32 from (4.164.51.22):
In Reply to: 560 hyd pump swap posted by Chris Brown on July 24, 2004 at 19:28:03:
Chris the only difference I remember is the make and then if you have the planitary PTO or the later clutch type PTO the drive gear that drives the PTO and pump could be different beacuse of the PTO. I don't remember the mounting plate being different for the pump. If you go to junk yard how will you know you are getting a better pump.
Post a Followup
: Re: Re: 560 hyd pump swap
