Farmall Tractors Discussion Board
Re: Wheel Size-f-20
Posted by Harold H on November 03, 1999 at 17:07:04 from (207.244.55.112):
In Reply to: Wheel Size-f-20 posted by Dean Englund on November 03, 1999 at 15:39:03:
Dean,
The F-20 was no longer being built in 1940, 1939 being the last year of production. However, there were no less than 10, probably more rear wheels available for the F-20. Most of the late F-20's, if ordered on rubber, had cast dish wheels which had 8 wide semi spokes and were called "adjustable tread wheels" which had offset hubs in order to be reversable. The rims were what you call split rims but IHC called them a "semi drop center type with loose side rings". The rims could be attached to the wheel in four different positions which with the reversable wheel gave 8 different tread widths. The older spoke type was non adjustable. The F-20 was available with 9.00 x 36 or 10.00 x 36 tires. Spoke wheels were still available I think. Lots of steel wheels were converted to rubber after the war.
Harold H
Post a Followup
: Re: Re: Wheel Size-f-20
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
