Re: farmall MD parts found in the oil
Posted by Mark in Mi on July 27, 2004 at 05:41:21 from (67.109.213.211):
In Reply to: farmall MD parts found in the oil posted by tim on July 26, 2004 at 20:44:50:
It could be a washer that is bent over the head of the crank bolt. These bolts hold the crank bearing caps in place. They are also to be secured by machanics wire. I would remove the oil pan and look over the crank area. I would NOT run the tractor until I did that first.
Thanks,
Mark
Post a Followup
: Re: Re: farmall MD parts found in the oil
