Re: 184 Cub idle too fast.
Posted by lee on July 27, 2004 at 20:01:37 from (24.24.95.246):
In Reply to: 184 Cub idle too fast. posted by Dieselrider on July 27, 2004 at 18:57:47:
Turn the slow idle adjustment all the way in til it just seats and then back it out 1 turn.
If it has a high speed adjustment I'd set that similar. Start the tractor and warm it up. Idle it down at the throttle stop as parts man said then adjust the low idle screw in til it stumbles some then out til it stumbles. Then find the sweet spot between where it idles best. Open up the throttle so it is running full governed speed (probably around 1800) and adjust the high speed needle out til it's noticeably rich then in til
any black smoke just clears up. I always try to set these tractors on the rich side, they seem to make best power there. Run it around to see how it performs under load. Tweak the high speed adjustment this way or that for best power.
If you find it not responding to adjustment you should rebuild the carb. I always tear them down and soak all the metal parts in carb chem-clean overnite and blow out all the little passages with compressed air.
Post a Followup
: Re: Re: 184 Cub idle too fast.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
