Re: rough running A
Posted by gene b on July 28, 2004 at 02:54:28 from (67.200.7.231):
In Reply to: rough running A posted by farmallgirl on July 27, 2004 at 14:04:15:
First thing to do is run a compression check. You can spend lots of money and time but if your engine is in bad shape all the tune-up stuff will not make a shot engine better. If it has 12v someone has already tried to fix something that was not good to start with. In the process going to 12v maybe didnot follow up with complete correct parts this happens all to often.
Post a Followup
: Re: Re: rough running A
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
