Re: Re: Re: harmonic balancer questions
Posted by Bob on July 28, 2004 at 10:28:53 from (66.163.134.177):
In Reply to: Re: Re: harmonic balancer questions posted by Dan on July 28, 2004 at 10:08:39:
Check with a dealer to see if there is a suggested replacement interval on your model (as there is on many diesels).
If your's has never been replaced, you may be due for a new one, as the rubber insert hardens over the years of heat and vibration, and no longer may be absorbing as much torsional vibration as it should.
While they aren't cheap, replacement is a heckuva lot cheaper than a broken crankshaft, and probably ruining the block along with it.
Post a Followup
: Re: Re: Re: Re: harmonic balancer questions
