Re: Re: Re: harmonic balancer questions
Posted by Allan in NE on July 28, 2004 at 11:46:16 from (148.63.132.164):
In Reply to: Re: Re: harmonic balancer questions posted by Dan on July 28, 2004 at 10:08:39:
Hi again Dan,
Yes, they are comprised of two pieces, which are held together by the center vulcanized rubber section.
If you have ever felt a pickup or car with a torque converter that was bolted in wrong, that is how they feel; only this shudder is happening at off-idle speeds.
You can think of 'em as a "motor mount designed for the crank". They essentially do the same function. Absorb and offset the vibrations.
I’ve only run across two or three bad ones in my lifetime, but when they are bad, you sure know it.
Allan
Post a Followup
: Re: Re: Re: Re: harmonic balancer questions
