Re: harmonic balancer questions
Posted by K.B. on July 28, 2004 at 17:40:20 from (209.163.30.70):
In Reply to: harmonic balancer questions posted by Dan on July 28, 2004 at 06:06:37:
You got good advice from Allan and Bob. I've always been told that if the rubber ring between the inner and outer pieces shows any signs of cracking or swelling, the balancer needs replacing. If you beat or pull on the outer ring, it is junk. Also, the outer ring of the balancer can "slip". The best way to check for this is to mark the relationship of the inner and outer pieces by drawing a line, put 20 hours or so on the engine, and you will be able to tell if it is slipping. Like Bob said, some engine manufacturers tell you to replace it every so many hours. I've never seen anything from IH, but I think John Deere says 5000 hours for some of their engines. If in doubt, just replace it. When the balancer fails, somthing else is going to break. I once saw an engine that failed due to a broken camshaft. The pistons hit the open valves, and the pushrods were "S"-shaped. What caused the camshaft to break? Vibration- the dampner was found to be in two pieces.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
