Re: Fan Nut - SC
Posted by Haas on July 28, 2004 at 20:08:28 from (12.65.66.86):
In Reply to: Fan Nut - SC posted by moose on July 28, 2004 at 09:35:13:
Don't try to get a wrench on the nut on the back side of the bracket. You will just make a mess. Loosen the shaft by putting a wrench on the hex on the front side of the bracket. Thats between the hub and the bracket. Make sure you use an open end wrench of the correct size (not a crescent wrench) so as not to round off the hex on the shaft. The nut on the back side is in a slot that keeps it from turning. Should only take about a half turn of the shaft to make things loose enough for the fan assembly to drop down.
Post a Followup
: Re: Re: Fan Nut - SC
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
