Re: Carbs on Farmall H
Posted by RustyFarmall on April 02, 2009 at 15:02:45 from (209.152.78.140):
In Reply to: Re: Carbs on Farmall H posted by Mike CA on April 02, 2009 at 14:28:40:
Might also be a difference in the size of the holes in the main metering stem, but I doubt if you will notice the difference, and that part is easily changed out if desired.
