Re: ground
Posted by TimV on July 30, 2004 at 14:02:15 from (67.136.204.74):
In Reply to: ground posted by Matt on July 30, 2004 at 13:22:23:
Matt: It could be either, depending on how the tractor is set up. The original 6-volt system was positive ground, meaning that the positive terminal should be connected to the frame. However, many A's are switched over to negative ground (and frequently 12-volt as well) in which case the negative terminal should be attached to the frame. If you have the original 6-volt battery setup, the odds are good that the positive terminal should be attached to the frame.
Post a Followup
Subject:
