Re: I got it to charge
Posted by lee on July 30, 2004 at 20:30:31 from (24.24.95.246):
In Reply to: I got it to charge posted by DANWV on July 30, 2004 at 18:38:04:
Sounds like you've learned just enough to be dangerous. Assuming that you have not yet burned anything up you should probably take the gen/reg to a shop to be properly calibrated. It may be your best path forward unless you can get your hands on specific procedures for calibrating the regulator to the gen. I'm thinking it is likely possible to calibrate the unit at home if the setup and adjustment procedures were available.
Post a Followup
Subject:
