Farmall Tractors Discussion Board
Re: cub radiator removal
Posted by Farmer Bob on November 04, 1999 at 18:52:35 from (207.227.237.103):
In Reply to: cub radiator removal posted by tony on November 04, 1999 at 15:40:13:
Tony, After removal of the entire hood with extensions/gas tank (all one unit), you should see bolts heads around the base of the radiator core where it bolts to the radiator support (heavy cast housing that contains the steering gear etc. Depending upon age and conditions, you may have to exert a little carefully placed leverage to get the radiator loose from the support housing. Good luck! FB
Post a Followup
: Re: Re: cub radiator removal
