Sleeve interchange with 113 and 123 engines - Stan
Posted by Dan on July 31, 2004 at 18:48:44 from (152.163.253.103):
I am about to overhaul my 1958 240. I have found that I have the 3.125" flat top pistons and the thin sleeves with the 3.3125" seal area.
I would like to use stepped pistons for an increase in compression, but I dont see a stepped piston kit listed for the 240 in either Valu Bilt or in the tractorkits.com site. They do list a stepped piston kit for the 113" A/B/BN tractors and it specs a 3.3125" seal area with the 3.125" bore. Am I correct to assume these sleeves and pistons will fit in my 240 without a problem? Am I going in the right direction with the stepped pistons in the 240? Are the wrist pins and compression heights the same?
Thanks
Post a Followup
Subject:
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
