antifreeze in oil in Farmall Model H
Posted by Mike N. on July 31, 2004 at 20:57:13 from (64.119.36.219):
I went to check the oil in my 1942 (1943??) Model H, after the end of a long WY winter. When I opened the stopcock, anitfreeze and oil both ran out! I pulled the head and don't see any obvious problems, i.e. head gasket or cracked cylinder walls. I opened the sidepanels on the engine and oily-antifreeze came out also. I am guessing that I did not have enough water drained out over the frozen WY winter and probably cracked a block...but where? Are there freeze plugs? Any likely places to look for a crack? What am I missing? If I did crack it, what is the prognosis? If you respond, please put subject line in or my wife might delete it!! Thanks in advance for the help!
Post a Followup
Subject:
