Re: Farmall A engine seized
Posted by Dennis on August 01, 2004 at 10:50:36 from (209.247.222.106):
In Reply to: Farmall A engine seized posted by Dennis on July 28, 2004 at 19:04:13:
Thanks for all the advice. I have been able to free the engine. What I did was fill an oil can with sea foam and oil and squirt about 4 oz into each sparkplug hole and tried cranking manually a couple times each day. Finally, yesterday I was able to turn the engine over. I still have the problem of 3 stuck valves. I am able to rotate the engine because I have the rocker arm assembly off. I have been putting penetrating oil on the valve stem with the hope that it will wick down and free the stuck valves. Does this sound like a good approach, or is there a better way? It's real tempting to tap on the valve stem with something non-metallic, but I can't bring myself to do it. Also, if the valves should free up, would it be advisable to button things up and see if it will run or are they some precautionary things to do to prevent this from reoccuring. I plan to change the oil and make sure the fuel system is cleaned out. Once again thanks to all. You saved me a lot of work.
Post a Followup
Subject:
