Re: keyed ignition switch for Super H
Posted by rustyfarmall on August 01, 2004 at 16:31:11 from (216.248.75.184):
In Reply to: keyed ignition switch for Super H posted by Ronald Shull on August 01, 2004 at 14:38:26:
My M is set up that way, don't know where the switch came from, it was there when I bought the tractor, and is mounted in the headlight bar, I really don't like it there. I think your idea is better, or, what about mounting it in the ammeter box? That way all of the wiring would be concealed as well as out of the weather. Check with NAPA, Car Quest, or similar for the switch, maybe even your Case-IH dealer, it shouldn't matter whether it is 6 or 12 volt.
Post a Followup
Subject:
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
