Re: No voltage at coil
Posted by john *.?-!.* cub owner on August 01, 2004 at 19:09:40 from (66.112.43.60):
In Reply to: Re: No voltage at coil posted by Terry on August 01, 2004 at 18:24:12:
Terry, Since it is a 12 volt system I assume the + side of the coil goes back to the keyswitch. I also am assuming it is a cub and not a cub cadet. Either you have a coil that is shorted , or a bad connection or faulty key switch. A shorted coil is unusual and should be causing the wiring to get hot. If you have a dropping resister (usually a long ceramic block with a terminal aon each end) to cut the battery voltage from 12 volts to 6 volts for the coil there is a good possibility it is faulty or has a coroded connection. Connect your coil and turn the switch on, then start working back toward the switch with your meter/test light.
Post a Followup
Subject:
