Re: No voltage at coil
Posted by lee on August 01, 2004 at 20:08:08 from (24.24.95.246):
In Reply to: Re: No voltage at coil posted by Terry on August 01, 2004 at 18:24:12:
6 or 12 volt coil? Resistor in the circuit anywhere? Fused anywhere between bat and switch and coil? Just a little mysterious to me not being there that you do not have 12 volts at coil + with the points open. I am thinking there is something wrong in the feed circuit to the coil but it seems you would still have 12 volts with points open. Suggests maybe also a shorted coil or capacitor. You will have 12 volts at coil positive all the time points open or closed when all this is resolved. Leave it at that for now. Back to what you wrote above. It sounds like you have 12 volts open circuit voltage (+ wire disconnected from coil) measuring from + coil wire to ground but maybe a poor connection or bad switch so when you measure open circuit you get 12 volts but when you connect and put a current (coil) load on it it fails to pass the current. If you hot wire direct from bat + to coil + everything else assumed good it should start. I would just touch this hot wire to coil momentarily to test for excessive current (excessive sparks) draw suggesting a shorted coil or condensor. Test it points open and closed. Don't touch the metal terminals or wires or coil, you may get a slight shock. Stay clear of the coil secondary or disconnect at the coil. If there is a resistor in the coil feed circuit somewhere don't run too long with a direct hot wire. Do you have a 6 volt coil? Jump around the switch terminals to test the switch. If you jump around the switch and it start it's the switch. Check the wiring from bat to switch to coil if switch jumper does not help. If a resistor is in series with coil (between switch and coil) somewhere it may be defective. If a fuse is in there somewhere it may be defective or poor connection.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
