Re: Another question for EL Toro(Hal)
Posted by El Toro on August 02, 2004 at 04:47:38 from (216.148.246.70):
In Reply to: Another question for EL Toro(Hal) posted by Abe on August 01, 2004 at 19:08:42:
Hi Abe, You could try spraying WD40 into the cylinders, but I don't think that will work since
you can't put the WD40 on the rings. Have you checked the valve clearances to be be sure the
valves are closing fully? You should still have that .017" clearance when the valves are closed.
I think you will have to tear that engine down if the valves are seating. Good Luck,
Hal
Post a Followup
Subject:
