Re: Friend needs help with 560 power steering
Posted by RPM on August 03, 2004 at 06:53:59 from (69.66.29.36):
In Reply to: Friend needs help with 560 power steering posted by dave w on August 02, 2004 at 19:56:02:
Its a problem with older tractors, the splines are part of a pricey assembly part number 372800R91 or 372802R91, last price known before it was discontinued was $472, if you cant find a good used one from a Farmall (460-560 same) we used to drill thru yoke and shaft and pin it with a hd spirol roll pin, then wire thru it, must use a good drill bit, hard steel parts, dont bolt it because you cannot get good press fit like roll pin.
Post a Followup
Subject:
