Re: Checking Hyd fluid (IH 460D)
Posted by Joe Evans on August 03, 2004 at 10:29:00 from (209.41.233.219):
In Reply to: Checking Hyd fluid (IH 460D) posted by Rmath IL on August 03, 2004 at 07:14:25:
Providing a 460 Utility has the same basic hydraulic system as the Farmall 460 (internal pump and common hydraulic oil/gear box sump), you need to check the hydraulic fluid by way of a 1/4" cap screw that threads into a level check hole. This is located roughly amidships of the left side of the transmission case. Remove the cap screw and oil should run out if the sump is full. If not...well, you know the drill. A Farmall 460 holds 10 gallons of fluid. Don't know about the 460U. It is OK to overfill to some degree.
Post a Followup
Subject:
