Re: Nippondenso Alt.on 350 Help
Posted by Doug in OR on August 03, 2004 at 21:58:06 from (24.20.250.197):
In Reply to: Nippondenso Alt.on 350 Help posted by Dale on August 03, 2004 at 20:28:54:
The L terminal is for the warning light. The S terminal is the sense - run this to your battery stud. Are you sure the G terminal isn't really the IG terminal? This would be to an ignition switch.
S is the same as the Delco 10SI pin 2.
IG is the same as the Delco 10SI pin 1.
L terminal might not need to be used. If it is used, tie it to a charge warning lamp.
Post a Followup
Subject:
