Re: Got the F-12 motor loose today
Posted by El Toro on August 04, 2004 at 06:22:54 from (66.119.34.39):
In Reply to: Re: Got the F-12 motor loose today posted by Jeff In Ontario on August 03, 2004 at 17:20:18:
Hi Jeff, Does your Allis B have sleeves? I restored a Farmall A that was stuck and I used transmission fluid to soak the pistons, several
came out with a little assistance from a block of wood and a big hammer. The other 2 came out with
the wet sleeves. I heated the sleeves with a torch and the pistons were easily removed. I used the old rods with a new sleeve and piston kit. It is amazing the abuse these tractors have endured and can be restored. Good Luck, Hal
PS: I had a Chevy Vega that was stuck and I used
the tranny juice on it and I then had sleeves installed in it. GM should've used the sleeves from the gitgo.
Post a Followup
Subject:
