Re: Timing Farmall B
Posted by Red Dave on August 04, 2004 at 07:01:25 from (24.104.94.34):
In Reply to: Timing Farmall B posted by BEL@IN on August 04, 2004 at 06:13:59:
If I understand your post correctly, your B is probably timed just fine as it is.
It should fire after TDC at slow cranking speed to protect you from kick-back when it is hand cranked. You don't want the timing advanced if you crank it.
Maybe somebody else sees it differently, but that's how I set mine.
Post a Followup
Subject:
