Re: Farmall H without sleeves?.
Posted by captaink on August 04, 2004 at 12:40:02 from (66.115.212.249):
In Reply to: Farmall H without sleeves?. posted by Jonathan on August 04, 2004 at 11:50:36:
My 2 cents worth… What you are considering is very unconventional and likely a “point of no return” for the block unless a lot of money is spent later. First hurdle will be to find pistons that will fit. Then later down the road if you want to go back to sleeves, the block will have been worn, and will need to be over-bored and “permanent” sleeves put in for the “replaceable liners” to fit into. This is where the lot of money part comes in. As far as heat, a lot will depend on how hard and long you plan to work the engine. I would suggest you consider just how much the extra cubes are worth before going this route.
Post a Followup
Subject:
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
