M throttle adjustment
Posted by tg on August 04, 2004 at 14:24:37 from (65.176.192.179):
Hi all--
I"ve got a pto generator hooked up to my 51 M. I need to know if there is a fine adjustment to the throttle speed on the M. I think it would be moving those two nuts under the hood that the throttle linkage/governor linkage is hooked to which also has a spring between those two nuts. Is this the way to get a finer adjustment of the engine speed? IH built those throttle handles with those notches and it seems that one notch is too low of a speed for the generator and the other is too fast!!!
So, is this adjustment under the hood the way to go, and if so, what"s the procedure?
Thanks for any info you can supply!!!
Post a Followup
Subject:
