Re: Farmall H without sleeves?.
Posted by El Toro on August 04, 2004 at 14:56:43 from (66.119.33.170):
In Reply to: Farmall H without sleeves?. posted by Jonathan on August 04, 2004 at 11:50:36:
Hi Jonathan, Take Rusty's advice and don't listen to your friend. Sleeves should've been used in all engines in my opinion. You're taking a step backwards by not using your sleeves. You can go from 3 3/8" bore to 31/2" with an oversize kit and you will have more than enough power to create wheel slippage under heavy load. Keep using those sleeves. Good Luck, Hal
Post a Followup
Subject:
