Farmall Tractors Discussion Board
Re: A oil
Posted by Farmer Bob on November 05, 1999 at 19:05:58 from (207.227.187.61):
In Reply to: A oil posted by Chuck on November 05, 1999 at 15:37:10:
Chuck, Crankcase capacity for your "A" is 5 qts. You should have two diamond shaped check ports on the left side of the oil pan, one slightly higher than the other. You turn these counter clockwise to open them to check the oil. Oil should drip out of the hole in the bottom of the
"petcock". If oil drips out of the top one, oil level is okay...doesn't drip from the top one but does drip from the lower one when opened idicates you're about a quart low. No oil out of the bottom one you better add some oil! (If you change the filter during an oil change (recommended) you should recheck the oil level after a warm-up period as some oil will be retained in the oil filter assembly. FB
Post a Followup
: Re: Re: A oil
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
